Kadett A help to retrofit seat belts
1 reading
365 views 2 replies 2 participants last post by  Maros-GR
#1 ·
I am thinking that is time to fit some seat belts to my Kadett and i would like to get some ideas, about how to do it, with minimal cutting and welding to the car. So what do you guys have done about it? Please post some pictures of your setups.
This is the only mounting point that i found in the car that can be used, under the rear window.
#2 ·
I’m not sure that cars imported to your country had all the mounts for seat belts, as I believe they were not equipped in the USA at least until 1966, may be 65. The other mounting points would be under the carpet on the rocker panels and the tunnel. Seat removal in the back lower might expose 4 other mounting points in the floor just before the shock mount frame
