Trick to getting headlight buckets out ?
1 reading
2.3K views 2 replies 3 participants last post by  lowkey (R.I.P.)
#1 ·
I dont want to break anything but cant seem to get enough wiggle room to get the bucket out.
Ive taken the front pivot apart,
Looking at the rear i have the two bolts in the bucket out, but cant get enough room to get the two bolts outside the bucket ?
Any tips or tricks ?
#2 ·
Rotate them 90 degrees and they will slide out.
Reactions: yellaopelgt
#3 ·
You don't need to take out the two bolts at the top of the bucket.
You take out the three bolts in the center at the top of the bucket, then rotate sideways, align the bottom with the center of the hole and lift at the bottom.
If it does not come out at first, then rotate the other direction.
Let us know if you need more help.
BTW, congrats sounds like you finally got the cars!
Also sounds like you are actually working on the. Good for you!
Now, where are the pictures?
