Distributor Wires???
21K views 21 replies 7 participants last post by  ungermm
#1 ·
This may seem like a silly posting but I was reading some of the archived threads on this subject and became totally confused with stuff like........the #1 wire is actually the #4 and the front is actually the back etc.
I have attached a pic of my current wire setup and I have the front (I assume is #1) connected to the upper left of the distrib. The manual shows it this way too. The car runs grea
If this is the correct setup, when I do the timing do I attach the lead to the #1 wire (the shortest one)?
If I have the wires on incorrect please let me know.
Thanks, Ray
Discussion starter · #3 ·
Hi Gene:
I would then assume my distrib is installed correctly and the wires are in the correct place and when I time it I will hook up the timing light to #1 wire and the timing ball/mark will be in the correct orientation.
This makes sense...............and I will let you know how it turns out.
ps...........m/o on the way today for you.....:)
Discussion starter · #5 ·
When I refer to the Black covered 1970 OPEL Kadett & GT Service Manual and look at the wiring diagram for the 70 Kadett Rallye it has the wiring setup pictured just like I have it in my car.
My guess is that if its wired incorrectly then when I did the timing and put the timing wire on #1 lead I would not see the timing ball on the flywheel. Is that correct?
Discussion starter · #17 ·
I sure opened up a 'can of worms' with my question and the answers were all appreciated. I checked my distrib and the timing mark is exactly at the 4pm position. At least with the way it was installed.........it runs.
Thats the problems one faces when they purchase vehicles that have had one or more owners. Things get changed or modified and it takes some time to sort it all out. I am not a mechanic by any means but I thought something seemed odd with the way my wires were set up.
Next question..........
When I do my timing how close should I have the timing light to the housing and what angle should the light be held at to get the best results?
Discussion starter · #20 ·
Today I purchased my first timing light and and set out to time the beast.
I ensured the vacuum lines were properly capped and the idle set at 700 rpm. I had no problems seeing the small bead and pointer. The bead was below the pointer by quite a bit. I rotated the distrib until the bead and pointer were matched. Shut the car off, tightened down the distrib and restarted. All was fine.
It actually idles good at 700........better at 750 to 800. I also noticed that when I reved up the engine the vibration I was getting is gone.
Not bad for an amateur...........
I was so happy about the whole deal I took my wife out this afternoon and bought her a new pair of high heels.............:)
