Well, now that the old Getrag is installed, the driveshaft of the Rallye needs to be shortened.
I have both new universal joints, front and rear. The problem is, no one has the capablility to install them, but the GM Factory! The solution to the driveshaft problem seems to be, use the old rear coupling intact, cut the front of the tube and use a small yoke with a GM T-350, 27-spline input shaft.
Any suggestions?
Dave
Any suggestions?
Dave
