You better put a large star type lock washer between the brackets because no matter how solid it feels while sitting on your bench it will begin to fold up and loosen the belt when you have vibration from the motor. I have one of those alternators in a box brand new that I never used because I didn't like the way the bracket worked and I went to the trouble to combine an aftermarket bracket with the stock one (welded together) and then had it chromed. It is in the attached picture on the right before I sent it out for chroming. The alternator that I wound up with is 105 amp chrome one and works with the stock bracket.Here are some pictures of my final mounting. I ended up making two version of the upper adapter to work with the stock upper arm. I didn't like the black one as it came out too short to provide a full swing of adjustment for belt tension. Once the lower was spaced and set to align with the crank and water pump pulley I noticed that a 3/16" or so thick flat bar would work perfectly with some tweaking as the extension.
So I made my second upper adapter and shaped it to insure alternator fan clearance as well as full adjustment swing. Once everything was tightened down it is VERY solid! And should be able to use a stock belt. I will double check that later.
Anyway, here goes with some pictures.
Mark is right! What you need is a rigid, slotted three bar mechanism similar to the stock setup. What you have created is a three bar linkage that, with the right amount of vibration and belt tension, will collapse (rotate and/or slide) in the middle and convert into a four bar mechanism.You better put a large star type lock washer between the brackets because no matter how solid it feels while sitting on your bench it will begin to fold up and loosen the belt when you have vibration from the motor. I have one of those alternators in a box brand new that I never used because I didn't like the way the bracket worked and I went to the trouble to combine an aftermarket bracket with the stock one (welded together) and then had it chromed. It is in the attached picture on the right before I sent it out for chroming. The alternator that I wound up with is 105 amp chrome one and works with the stock bracket.
The pulley is from the original Opel alternator.You could find a rebuilder in your area, maybe they can change the fan for a smaller one. The pulley also looks to be a lot bigger than the Opel alternator has, a smaller pulley would improve charging at idle.
Do you have the fan from the original Opel alternator?The pulley is from the original Opel alternator.
There be two different "stock" brackets..Today I tried adapting the stock aluminum bracket to work with the GM 105 amp alternator that I had. It is from Autozone - a Duralast 1532-6-7 with the 10 o'clock mounting that I've used previously in my GT and Manta with the F bracket. Upon completing the shim swap and some grinding I discovered that the cooling fan on the alternator will not clear the bracket.
The alternator used by the OP is different and does not have the clearance issues that I had. Looks like it's back to the F bracket for me.:sad:
With the heater blowing on high, the wipers going and the headlights on, you won't go very long. In this scenario it's a cold wet walk home.I've read several of these threads on upgrading the Opel GT alternator. Can someone explain why people are upgrading to higher amperage? Are they adding things to the car that requires more capacity? I have two GTs with original alternators. Both will produce positive current even with everything turned on.
Just asking?
I believe that some Opels came with only 28 amp alternators. They had no problem keeping batteries charged.With the heater blowing on high, the wipers going and the headlights on, you won't go very long. In this scenario it's a cold wet walk home.
The 35 amps just aren't enough. Not to mention that the Opel alternator is 40 years old and the mechanical voltage regulators are prone to failure.
I can understand if you are using that many options. I am running a redline weber electric fuel pump on my yellow GT. It is rated at 6 amps at full flow. I don't bypass to the tank, so it is pumping very little and consequently using very little amperage.The stock alt can not handle the extra Mods we add to these cars... electric fuel pump draws approx 7 to 10 amp, electric cooling fan up to 30 amps, electric windows, after market radio. Fog / driving lights. all this drains power from the alternator, when you use up all 35 amps the alternator. Is overworking, low power low voltage. Under powered....That why we use a higher amp alternator to handle extra devices
Yep, I tried this last year and ran into the same problem and ended up going back to the "F" bracket too.Today I tried adapting the stock aluminum bracket to work with the GM 105 amp alternator that I had. It is from Autozone - a Duralast 1532-6-7 with the 10 o'clock mounting that I've used previously in my GT and Manta with the F bracket. Upon completing the shim swap and some grinding I discovered that the cooling fan on the alternator will not clear the bracket.
Yes, buttttt:In my opinion it would be better to replace the failed part with a used factory unit or one that is similar from OGTS. BTW, a 45 year old alternator is probably more reliable than the junk being sold today. There is a high rate of failure among alternators and starters right out of the box these days.
